I need help on bartwists.
MrScoot
put your hand all the way on the inside of your grips on the metal, its way easier because the bars will just slide through your hand. ive done them on 22 wide bars, also for me its harder to do them on t-bars but idk, also, keep your hand very loose around the bar, basically take all fingers off except your thumb, pointer, and middle finger. itll make less friction and the bars will again slide better through your hand. hope this helped :)
Tips on the wrists: make sure your wrist slides by the end of the grip. If your hand is on the inside of the grip too much, itll hit your wrist. This does not mean start on the outside, it just means you need to loosely slide your hand to the outside when doing the trick. Keep your hands where you always have them, there's no need for a special hand position. Bartwists come out good if you let them flow easy. LOOSELY (extremely important, holding it too tight means too much friction for it to flow, hence some people suggest water to learn to slide your hand properly) twist the grip, and slide to the end of the grip and come back.
Since yours bars are 18 wide, you'll want to lean your body back a little bit so they don't hit you.
Staying on the deck is commitment. Force your feet to stay on, learn em flat to ensure that. It's an awkward motion and it always dips the deck, one of the few tricks that does that and instinctively makes you want to come off.
Here's a vid of me doing some a few years ago right after I first learned them. If you pause at 10 seconds, you'll see my deck is almost vertical when I'm doing the motion. It's just dedication, man. Take the tips you know and PRACTICE. Once you know the technique, all there is is practice. There is no magic technique to learn something immediately. ( http://www.youtube.com/watch?v=lbJijzrfRxo )
i find it helps to tuck your legs in, like you are trying to curl up in a ball. this way , your feet cant come off. it works for me anyway! :D
Jacob B
Don't wet your hand, put it on the inside of the grip, not the outside. Practice the motion. It's all practice man. Take it from me, I'm one of the only people who has done a tripple bartwist i know what i be talkin about brah.
video please? haha sounds dope
Malik S
its the motion, i learned them flat first and i still cant do them fly out,
just keep doing the motion when i waqs learning them i did it for the ten mins strait then i had it down. also when doing the motion kind of tuck your scooter behind you while doing the bartwist
Jimmy C
this. i 360 bar twisted a 6 set. just practice the motion
tylerbillman
I want to learn 360 bartwists. Whenever I would try them I think I'd hold the grip too far inward and also wouldn't pull up hard enough because the deck always got away from me.
