Locking folding mech help please
pure
I locked my folding mech today and the bolts dont stay in when I ride it and it dosent stay tight like up right. any suggestions on what I have to do to lock it properly. heres a video on how the bolts look right now http://www.youtube.com/watch?v=J3iqYGo1m-4 please help me out and tell me what I have to change. thanks
pure
how do i tighten up my headset? and in your picture your bolt looks like it covers the whole hole mine if u push it up it will go out of place. and do I need the washers on the insides or on the ends?
theres a headset cap, and a nut untop of it
it should be the nut closes to your headtube
tighten it up, but make sure it aint too tight, as you wont be able to turn your fork....
pure
what do u guys put in the empty space though and is the nut your talking about the big one above the fork?
pure
the thing with the 2 bolts and the little screw thing in the middle? dont I need that thing?
Yes that thing and no you dont need it. Its used when your using a stock folding mech so the headtube doesnt shake as much, but when you lock it, it prevents you from being able to tighten it as much, hence why you headtube still shakes. So unbolt your foldy and make sure to use the right size allen key so you dont strip the screws. Then take it off and tighten the shit out of your bolts and you should be set.
Spencer Steed
Spencer Steed
get bigger bolts then
well anyways when you re bolt it (with lock washers) put the 3/8 bolt behind and and one of the 1/4 bolts in the front. it helps a ton. and take the plate off before you do it or else it wont work
jeff26
i think its 1/2 inch in the main hole, 3/8 for all the others.
edit: from super modding thread
Bolts for locking your folding mech
Get these at your local hardware store (Brandon Kilbury's sizes)
-2 1/2" by 3/8" bolt
-2 1/2" by 5/16" bolt
-washers
