Madd Blade Brake?????
ryankeong
Okay so i have a madd brake and spring and i want to put it on my razor pro model i have grinded it dow so it fits in but wen i put the madd spring in the brake just sits on my wheel and i cant get the brake bolt through if i use a stock pro model spring does anyone no hat to do???
ryno
put a bearing under your spring...
and if it coems out super glue it
manly blades are fuckheads and grind the brake thing down and makes the brake rattle like fuck
Hep Greg
use a pro model spring backwards (bent end on deck, straight end on brake). thats what i did. it works fine.
Jason
Old topic, but I got a Blade brake on with a Pro spring. Just grind the bolt into a point and it makes it easier.
Geordie
i swear that they are grippier, i had tyre taps and fufs down when i was running a madd brake, then i decided to run my pro brake and sell the madd 1 and everytime ive gone to do a tyre tap or fuf since then ive slid out onto my ass
Joe Armstrong said:
not worth puttin 1 on they dont do anything they just look cool
no way man, they are so much better than pro brakes. ive rode about 3 pro brakes down to nothing(through to the wheel) blades dont do this they are the shit
AnthonyPellino
Anthony Pellino
And they say STOP on them, how could you not want a brake that says STOP??!
just incase you get confused
seriously blades are mad for retarted kids
the forks have arrows pointing the way they need to go
and the brake says stop
loll
