Madd Gear Pro Headset Troubles?
mg123
Hey, my headset is giving me the shit because when i tighten it its to tight and wont spin but when i losen it just a little bit its to lose and wobbles and rattle and stuff... ive tried several different bearings and still the same thing?
it may be my forks im not to sure but any help would be appreciated!
i had the same problem when i had an mgp and i just took out the rubber dust cover thingy out of the bottom bearing cup and it worked fine
Zaηe
Keepin' Peace
No, clean your bearings out with a rag with some sort of solvent on it eg: thinners.
Re-grease your bearings or apply headset lube. Then, get two spanners or adjustable or whatever to tighten your headset to the right point where theres no wobble and spins decently.
I had this soo bad, then the bottom bearings exploded, bottom bearings were compltetly broke then it started locking up. Finally changed the head set soo much better. BTW i feel so cool talking about my maddgear
