conordavidson
How do you change the headtube angle on a pro-model so it's completely vertical? I wanna do this without welding of course. I also have a spare old A headtube if that helps?
Thanks.
Thanks.
AJ Storcella said:damn... that looks sick... but how can you ride without a brake on your Old A... wouldn't it be harder to fakie... cuz if you hit your wheel your going flying man!!! =] haha
kolby crouch said:i got a brake bolt in the front and a 7/16 bolt behind
Exactly opposite way. When you're brakeless and going forward, then the back wheel might lock and skid.Pirate Alex said:Brakeless would be more dangerous for going forward, if you're going fakie it would slow you down, but not totally lock up the wheel.
Im with Alex on this one. If you hit the brake going fakie you go flying backwards, if theres no brake and you shoe hits it the wheels just going to slow down, if your putting alot of pressure on it, it might be a different story thoughMadis said:Exactly opposite way. When you're brakeless and going forward, then the back wheel might lock and skid.Pirate Alex said:Brakeless would be more dangerous for going forward, if you're going fakie it would slow you down, but not totally lock up the wheel.
But if you ride brakeless and fakie, then the wheel will lock and it'll not skid - it'll throw you over your back.
