PHOENIX Deck rear axel help
short_bus_Scooter
Got a used phoenix today from Colby on here, great condition but there is no rear axel or spacers, does anyone know what you can substitue in as the axel and spacers? I tried using a old razor axel and A model spacers but its to long and spacers are to wide. Any help would be greatly appreciated.
Billie Rainbow
try getting the middle out of bearings, pretty sure they are the right size. as for axles, just use any that are longer than the dropout are wide and then compensate with spacers.
short_bus_Scooter
Alright I think thatll prolly work since the bearing spacers are a hair smaller then the a-model spacers, and as for using a longer axel wouldn't it slip back and forth thru the wheel? Would getting a bolt and nut from hardware store be better?
CJ Treihart
this is wht im doing
got the middle out of 2 bearings for the spacers inside the deck
used a razor pro back axle
and 2 bearing spacers on the outside
works perfect
short_bus_Scooter
axel's long as hell tony, we can go hardware store tomorrow if your not at the park by the time im off work. and CJ also if the spacers are on the outside the wheels gonna wobble on the inside
CJ Treihart
u have bearings spacers on outside1 on each side and 2 middle of bearings on inside doesnt stick out tht much it works fine so at the end u need
2 bearings spacers
1 razor axle and thread part
