[poll] Zero Offset or Normal Offset Forks (I'm making CNCed forks)
What design do you like better?
  • Zero Offset
    Votes: 0 0.0%
  • Normal Offset
    Votes: 0 0.0%
  • Aluminium
    Votes: 0 0.0%
  • Total voters
    1
saltwater
I might make some forks if i can get some material.
I need some 3mm and 8mm sheet and 35mm OD billets.
Anyone with idea's and links to get material will be appreciated!
The wheel represents a 110mm wheel.
Zero Offset:
Normal Offset:
(note that little bit on top of the front plate isn't part of the design)
James Scown
whoever votes steel/aluminium is retarded. forks should be steel as aluminium is easier to break so the poll should just regard zero and regular offset
Manzie
Zero offset makes nose manuals/hang fives about 4 bazillion times easier. And barspins more fluid.
JamieBowe
Zero offset is better for barspins, And no matter what way your bars are facing its going to be the exact same.
saltwater
James Scown said:
whoever votes steel/aluminium is retarded. forks should be steel as aluminum is easier to break so the poll should just regard zero and regular offset
Air Craft grade (6061-T6) Aluminum would be just as tough as mild steel and with out the weight, but it would cost heaps, I'd have to order from America.
Roycee
normal, zero offset means no side is better for footjams
if they are threaded then dont use alluminium, the bars will rip off teh threads
Billie Rainbow
if they are threaded then dont use alluminium, the bars will ip off teh threads
Yes you speak the truth there royce
i'd get so bored not doing footjams n stuff cuz there sooo much fun
and yeah thread+aluminium=Fail
(more than likely in mid air, and that would not be good, especially for royce) :O
Roycee
haha ily billy
