Proto Brass Knuckle (Help)
COzzie89
I have a threaded fork and my bars have slits in them, can i put a proto brass knuckle on the bars instead of the double clamp? and will it do that same job?
Waste of money. Get threadless forks a threadless headset and cut the slit off ur bars. If u use scs with threaded stufff your a fucking loser im sorry.
Jacob D.
Why would you even buy it if ur not running threadless? To Look cool?
you would be surprised how many little kids have done it...to answer your question yes you can, just put the starnut in you fork put a locknut on it put on the scs and tighten it...BUT if you do that you will fail so bad, it defeats the purpose of compression if you have a fucking locknut
