scs clamp with HIC compression
yo, I'm just wondering if when you use an scs clamp with HIC bars can the bars have a slit in? I know if you are using scs you need bars without slits. could someone please help:)
Billie Rainbow
if not get an old normal sized steel bar and cut some off and put into bar and make sure its plenty higher than the slits
You could, but it would raise your bars 2 inches higher.
Just get an old piece of 1.25" OD tubing, put the shim on it, and put it in the HIC bars/slit.
Might have a hard time removing it though
