kalgoorlie scooter rider
my scs starnut is all tight and have all the caps on my headset but it is still lose help please??
If you want it off your bars and forks.do you undo all 4 clamp bolts???
I hope you realize that you have to undo all 4 bolts, take the bars off, and take out the compression bolt to take off the fork....If you want it off your bars and forks.
If you only want your bars off, then you take the top2 out, and you only want the fork off, then you only take the bottom 2 out.
