my brake keeps on getting loose on my deck because of my reinforcements is it possibe to put the nut on the brake bolt so it will stop getting loose any other suggestions
Sounds like you need a longer bolt with a lock nut and then drill true the reinforcements like a bigger hole on the outside wall than on the one facing the deck so that the bolt can sit on half the reinfocement. Kinda hard to explain but.
What kind of reinforcements do you have? Whichever you have, the best bet is to put some loctite on the threads then tighten it all the way down and let it dry.
