What clamp/compression do i use to make it WORK?
I have these parts ready to be made into a scooter:
District v3 bars (AL with outside oversized and starnut pre-installed)
District v2-i deck
Phoenix Forks
What clamp will work? I know i can't use HIC because of the regular sized bars on the inside... and the phoenix forks have a pre installed starnut as well so ICS won't work... Last option is scs or switch parts out... but ive seen others post about proto's.
So will a full knuckle proto clamp (if i take out the spacer/shim in it) fit on the bars and secure it to the fork enough? ie; will this clamp work http://www.krypticproscooters.com/products/Proto-SCS-%2d-Black.html
with my setup?
And i read somewhere that phoenix forks dont really fit well with d-v2-i's because of the longer fork neck
