Wheels and bearing problem HELP
james blott
Ok i got proto wheels
when i put the bearings in and spacers the wheel goes heaps tight and the bearing don't spin
If i take the spacer out the wheel wobles how do i fit this or do i need new wheels
michaelpytel
sounds to me like your spacers to small and isnt doing its job properly, what kind of spacer? have you tried others?
michaelpytel
ok then yeah sounds like your spacers to small so when you tighten its like not haveing a spacer at all to an extent, and your bearings are being compressed together like )=( instead of l=l so just try different, larger spacers.
