your custom/homemade parts thread
cuz i got the deck from tprscooters and i like the sharp edges better so i just cut em
also the freestyler is straight the edges and the flight is like round if u know what im saying lol
Dub post,kill me.
But basically I filled the threads with JB Weld let it dry, sanded and wet sanded it smooth, installed a starnut, and gave it a fresh coat of black paint, looks pretty legit and I have no doubt in my mind itll work, I guarantee it.
im going todo this with a lucky fork , how much does this stuff cost?
Broccoli1
Where can I find the metal to make a flex fender?
Steel: you'll want to order Spring Steel, problemo is that it is not very easy to work with since it is hardened or needs to be hardened to work as a Spring. basically you heat it up red hot- this anneals it(softens) which allows you to work it: Cut it, drill it bend it.
Then you have to heat it again & quench it- this makes it hard again but brittle.
heat it up again to Temper it- takes some of the brittleness out and you end up with a "Spring". Something you can bend but returns to its original shape.
Example is the leaf Springs under a car or a simple Metal ruler.
Stainless Steel- but that is even harder to work with since a basic set of drill bits won't be able to drill through it.
Aluminum: same thing- to get the properties of strength yet Flex it isn't something you buy off the shelf.
Now with that being said you can always find something that could work for you.
I think there was a Brake somewhere back in this thread.
...and this dude is selling fenders for 10 bux shipped
http://www.scooterresource.com/forum/showthread.php?t=65229&highlight=flex+fender
That is a deal. I'm all for making my own sheite but 10bux to my door is a bargain- as long as they hold up.
Michael.
damn I should have taken pictures but I put my animal barends in my districts. I grinded the excess plastic down with a dremal and it came out pretty legit. The bars ends work like a charm <3
