Randall Dalal
Its welded together.
Lucky is a solid block of alu.
Doesn't matter if the deck is CNC'ed, if its all welded togethor then it is technically in "one piece" making it a one piece deck.
BeCuAsE tHe BrAkE iS AnOtHeR PeIcE D00d!!!!!!11
Who gives a dump how many peices are in a deck. The amount of peices in a deck does not vary with how solid it is, or how strong it is.
With that logic, nothing can be a one piece deck because you have to put the fork into the head-tube and it doesn't come with it in. The brake is not part of the "deck" so therefore it is still a one piece deck.
Actually yes it does, for example on a razor pro you have to bolt the headtube to the foldy, making it less strong then something welded on.
