Before you use WD-40, READ
If you use WD-40 to get you bearings in, make sure it doesn't get inside the bearing. It will attract dust and act as a DE-Lubricant.
And even more important, do not get any WD-40 on the wheel itself. It will cause the urethane to deteriorate
