NEW AND IMPROVED! TRICKS YOU NEED HELP WITH ZOMG
JoelanPlz
what most people i know call a hurricane? feeble turning your bars towards the ledge so your body spins
1:20 without all the other jazz
thealexbuffery
Gold Member
so FS feeble then slide into a fakie BS feeble?
i do them BS to FS just cause haha, not sure why but im trying to get FS to BS
just go into the normal FS feeble, once you're grinding, twist your upper body in the direction you're going to slide in. it will seem as if you're slipping out, but push the deck against the ledge and it should lock in again, then do whatever tf you plan to do out of it haha
Ignacho
Feeble bsfeeble -180 - feeble bsfeeble
(Ledge)
I can feeble bsfeeble - 180 - smith -180 off but I'm just having trouble throwing myself round enough and when I do I'm landing too far away from the ledge.
Help plz?
try to get them without grinding first, just like stalls, and as you get them more locked in a stall try to get them grinding but slowly, so you have more time, and as you get better you'll lock them
Bror Svensson
Gold Member
you can't do a bs feeble to fs feeble, fs and bs all have to do with what way you were pointing when you hoped onto the ledge, what he did in the video was a fs feeble to fakie fs feeble
DeviinGilly
FS fakie feebles are on of the easiest tricks (in my opinion) , and they look so solid, you can do some nasty combos.
parrish
yes
just call them fs hurricanes
no, hurricanes your body stays the same and you move your bars/deck, on a fakie feeble you do a 180 on. Both can be done on rails and ledges. You more quickly snap out of a hurricane though, and 180 out of a fakie feeble.
Bror Svensson
Gold Member
yes
Please explain, isn't frontside and backside all about which way you point when you jump into the trick from the ground?
parrish
yeah its about how to approach the obstacle. I wasn't talking about that though, I was talking about the difference between fakie feebles and hurricanes.
Ignacho
so when you do it on a rail and your body and your bars/deck do a 180, would that be called a fakie board or what?
parrish
No its still a fakie feeble. A feeble isn't because its on a ledge, its because its on your back dropout. Thats the difference between a boardslide and a feeble.
Hunter Treviranus
scooter tricks are weird. It all depends on how you translate a "skate" trick or a "bike" trick to a scooter trick.
In my opinion its a feeble if the back dropout(or peg) is grinding and your wheel is riding on top of the obstacle,but thats translating a feeble from the BMX version.
-The other "feeble" that could be the trick elliott Arnold does where he does an icepick but hangs over the rail,which some what translates to a feeble in skating.
-"crooks & crookeds" -"Crooks" I believe is what everyone mistakes as an "under-crook",and "crooked" is the bike version where you have a peg in the front and a peg on the back(on opposite sides) and grind on both pegs.
