scs problem
parrish
u have to stretch them, put a bolt in through the threaded side then put a coin in the slit and tighten it till its streched
edy boi
i had this happen to mine u put the bolts in 1 at a time if u cant do it with any of the other ways cut the bolt in the middle un screw the allen key half then cut a notch on the other side thats sticking out and undo it with a flathead only way u can do it dude sorry
Nah, grease helps a lot. You know what happens when cars run without oil?
They don't. That's what.
Same thing. Ungreased bolts are going to be much harder to get out than greased ones
I suggest taking the bolts out, greasing them, then putting them back in
mattttyler
but the whole point of bolts is to keep things in place..and the whole point of grease is to loosen things up and keep them running smooth.
so they dont seem like a good mix?
