your custom/homemade parts thread
jare88
Jerry
JacobUrrea08 said:
jared (K) said:
now that i think about it, all wou would have to do to make a scs is to have some relatively thick metal tubing, a hacksaw(to cut the slit in the back so it can acutally clamp), one small sized drill bit(for the screws), and two different sized large drill bits(one side to fit bars, one for compression cap/forks). holy shitt, that would probably only cost like $20 bucks and a couple of hours. sorry proto. i think i will acutally try this, possibly a tutorial. ghetto knucks ftw nigz
if anyone who already owns an scs can tell me the dimensions it would help a bunch. side to side, front to back, and height are needed. also, it would help if you could tell me the inner diameters for both the bottom and top half. thanks, i would love your help.
yeah and instead of threading them into the clamp you could just use lock nuts so you wouldn't have to worry about the bolts stripping or anything.
yeah, that was pretty much my plan. i understand how difficult it is to thread shitt. And don't think i'm just some dumbass newb, i have experiance making shit or a scooter, i just don't post like crazy so i don't have a high rating like most of these fuckkers
jare88
Jerry
^ i thought about that, but i'm pretty sure he doesn't have a patent. On the actual Proto website, it says patent pending under "brass knuckles scs". Plus, if he wants that type of compression sstem to be "Standard", how can proto excpect to be the only ones to be able to sell that type of compression. that's called a monopoly. It's like how you can buy inward compression, frid, and old sr compression, and they are all types of inverted compression systems. i am simply going to make my own "standard compression system". If they want i won't call them knuckles. and im not going to sell them, i'll probably make only one...
Zaηe
Keepin' Peace
Ashley said:
i love those kucks!
i need help.. i have a trolly bar, well.. i used to have a trolly bar and i cut it down to good peg sized.. pegs! but i need to know how could i put them on my scooter :S lol, any one got any ideas?
thanks
put washers on each side of the peg (pole whatever) and get a long bolt and put the bolt through the fork, deck whatever then slide the peg on (with washers on both sides of the peg) and then there should be some thread hanging out of the peg so just put the nut on that and tighten.
ok?
Hey, you're retarded.
First of all, it's not hard at all to "thread shitt." You're just a dumbass and don't know how, so you assume its hard.
Secondly, you can't even spell "experience" correctly. and I will truly be surprised if you succeed in making anything that works as good as Andrew's SCS. Good Luck. You're going to need it.
saltwater
JDBen said:
can't he sue if you tell people how to make them? just wondering...
Ahh no it doesn't take much to figure out how to make 1 anyway.
Just some general knowledge about engineering and manafacturing helps besideds i don't think he has the money to sue.
I pretty sure he does, on the webe site it says 'Patent pending' which means its waiting till the patent design goes through (takes some time) and its likely it has now been patented (unless Proto called it off, but meaning he would have wasted money)
Proto's calling it standard to build hype and know other reason. IMO.
If your going to make 1 you won't be in much trouble, as long as you don't profit from them you should be fine
nickbrah
i assumed a patent was passed when he released his 2nd batch with SCS where it once said Pat. Pen. or whatever. Just make yourself one, you can always destroy it if its brought up as physical evidence in court case and the trial would be dropped.
jare88
Jerry
ok, sorry for a typo asshole(bret lentine). I swear to god I'm smarter than you so suck my left nut. I bet you have so many "experience" points doing that, if you were a pokemon you would be level 100 you fucker. To thread the inside of a metal hole you use a tap drill and twist the tap inside of the fuckking hole. It's hard to keep the tap(the device that cuts the threads) straight, especially if you are using a handheld wrench, which is what i own and was the issue that i was adressing with my previous post. I'm sorry that you had to be an immature fuckface. (I purposefully mispell the swearwords with one letter just so you will know what i'm saying to you. Oh, and its the internet, so it doesn't even fucking matter if things are mispelled. Go shit in a frying pan, let it cook in the gay-ass arizona heat, put a little butter and salt on it, then eat it.
I'm not going to make more than one, so the patent thing really isn't a problem. If I post instructions, I would just consider them instructions on how to make a compression system that is better than normal ics.
Dom Marconi
dude, i dont think you get it. try and carve out you "GhEtTo KnUcKs" and when yuo finish them, come and show everyone. have fun. its not as easy as yuo would think.
jared (K) said:
ok, sorry for a typo asshole(bret lentine). I swear to god I'm smarter than you so suck my left nut. I bet you have so many "experience" points doing that, if you were a pokemon you would be level 100 you fucker. To thread the inside of a metal hole. You use a tap drill and twist the tap inside of the fuckking hole. It's hard to keep the tap(the device that cuts the threads) straight, especially if you are using a handheld wrench, which is what i own and was the issue that i was adressing with my previous post. I'm sorry that you had to be an immature fuckface. (I purposefully mispell the swearwords with one letter just so you will know what i'm saying to you. Oh, and its the internet, so it doesn't even fucking matter if things are mispelled. Go shit in a frying pan, let it cook in the gay-ass arizona heat, put a little butter and salt on it, then eat it.
Hahahahah wow you're really serious? How old are you, 12? Pokemon? Really now?
Do you have any idea how fucking dumb you sound? "I bet you have so many experience" No, I take that back, you're right, you're a fucking genius! You are so much smarter than me that I should shit in a frying pan and eat it. It makes perfect sense.
charles
we have us a regular einstein on our hands...
